Web UI Login
rklda
Unable to login in to the web UI of CSCP version 2.7
I have a ssh admin, root and collectorlogin passwords and can login via the cli.
I've tried both admin and Admin123 with the Admin#123 password to try and login to the web ui but no luck.
Can I reset the admin web UI passowrd from the cli?  or add a new web ui user via the cli?
jumin
Hey rklda,
I will private message you a workaround to try.
Justin
That worked, Thanks!
Can you share what was done to resolve this? This is the exact scenario I find myself in. Thank you
Hey bryan.perina,
Unfortunately, this was version specific and the CSPC has been updated so that this workaround no longer takes effect.
Currently, the only methods for forgotten passwords are to answer the security questions or if an email was entered in the Email Settings, a new OTP can be sent to the email to use as a password reset.
Justin
