Cannot upload entitlement file to CSP Collector
Trent Hewitt
I cannot download the entitlement file from the portal. When creating the entitlement file, I click download and get a message a few seconds later saying it failed to download. I've deleted and recreated the entitlement a number of times. I've tried this using ffox and chrome (site doesn't even render under IE).
I've also received an email after creating the entitlement to download. When using that link, the system downloads an empty zip file. This has occurred every time I've generated an entitlement.
I've ensured that the CSPC appliance has connectivity to the cisco sites over 443.
Any help is appreciated.
Trent
jumin
Hey Trent Hewitt,
I believe the issue has been corrected in the backend.  Can you see if the entitlement file can now be properly downloaded.
Justin
jumin
Hey Trent Hewitt,
I believe this may actually be an issue on the Portal's end.  I will troubleshoot further to confirm and let you know what I find.  If this is the case, we may have to wait for DEV to make some fixes before you can download the entitlement.
Justin
jumin
Hey Trent Hewitt,
Justin
Thanks jumin
That worked. I was able to create a new entitlement and download the file.
Trent
