05-18-2018 04:22 AM - edited 03-12-2019 07:48 AM
We would like to configure GSPC Email settings, please advise what user name/password we should enter, is it admin credentials used to access CSPC?
What email sender IP address we should configure in our SMTP server? it should be collector's IP address?
Solved! Go to Solution.
05-18-2018 05:57 AM
Sender's Mail ID -- This is the Email Alias that the CSPC will use while sending an email. For this value , please use a valid sender ID (within your company). A descriptor can added to it at the end to also help distinguish the emails. You can use the "+" symbol to add the descriptor.
Example Sender ID -> "Name+myCSPC@abc.com"
Depending on your SMTP settings, a username/password may be required to send an email. If not required from your SMTP, you can leave these blank.
Thank you,
Jarrett
05-18-2018 05:57 AM
Thank you,
Jarrett
05-21-2018 02:45 AM
