CSPC stuck in Apply-in-Progress when updating to version 2.7.4
RicTodd89
I am upgrading from version 2.7.3 to 2.7.4 and the GUI has shown "Apply-in-progess" for over 24 hours now.
Can someone please assist?
2 Accepted Solutions
Direct access to the root account is disabled. However you can issue the command "pwdreset collectorlogin 90" to generate a password for that username as well. From there you can SSH into the user "collectorlogin" and move over to root using the command "su -" and providing the root password.
Thank you,
Jarrett
I had the same problem (CSPC stuck in Apply-in-Progress when updating to version 2.7.4) and solved it with the workaround page 6
Thank you very much
AL
6 Replies 6
Supriya Patel
Hi User,
Do you have CLI access to collector. Please login to collector using CLI via user admin. Please reply with output of 'show version -d' and 'show download' and 'show apply'
Supriya
admin# show version -d
Build-name : Collection Platform Software 2.7.3
Package-type : ServicePack
Version : sp-30.0.3-0-0-lnx64
Component : CSPC Base
Version : 2.7.3
Package-type : JeOS
Version : jeos-30.0.4-0-lnx64
Component : AdminShell
Version : 1.7
Component : LCM
Version : 1.7
Component : CASP
Version : 2.7.4
Component : ConcsoTgw
Version : 1.7.2
Component : Hardened CentOS
Version : 6.8 patch#0
show download
Version : sp-30.0.4-0-0-lnx64
Download Location : /opt/LCM/tmp/sp-30.0.4-0-0-lnx64-package.zip
Status : Downloaded
Start Time : Dec/07/50287 03:31:54
End Time : Apr/26/2018 14:37:47
Reason For Failure : -
show apply
Version Number : sp-30.0.4-0-0-lnx64
Status : Apply-in-progress
Start Time : Apr/26/2018 14:38:24
End Time : -
Can you please check and see if the re-applying steps found in the 2.7.3.2 release notes helps to resolve your issues? The steps start on page 6 in "known issue".
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-ReleaseNotes-2732.pdf
Thank you,
Jarrett
Apologies for being unfamiliar with Linux, but how would I access the root account in order to apply these commands?
I issued the pwdreset root command and logged in with the usual admin account username and tried the root password that was generated, but I am still unable to access the root account.
Thank you,
Jarrett
Thank you very much
AL
