Failed to verify Enable Password
RonF
I have set up a specific ID for use with SNTC that was granted specific permissions to access the CLI commands that are in the standard data collection profile.  When I test it with "Verify Device Access" and then look at the result report I see that while it works fine for 126 of my devices, there's about 81 of them that under SSHv2 give the error "Failed to verify Enable Password".  When I try to log into some of those devices I get a ">" prompt, and upon then entering the "en" command and reusing the same password I get a "% Access Denied" error.  I have taken that up with internal support.  But with others, when I use the credentials I get in fine and get a "#" prompt that permits me access to the commands I need.  I have tried running the report both with and without having the ID and password repeated in the "Enable User Name" and "Enable User Password" fields in the "Add/Import Credentials" wizard.
What is causing this?  What is the effect?  What is the fix?
8 Replies 8
Jarrett Pomeroy
Can you please also include what device types you are having the DAV issues with?
Thank you,
Jarrett
A WS-C6509-E running IOS 15.1(2)SY7
A WS-C4948E running IOS 15.0(2)SG8
A WS-C4500-X running IOS-XE 03.06.04.E
A WS-C3750V2-48PSS running IOS 12.2(50)SE5
Thank you for the details. Can you please let me know what version of CSPC you are using as well? I was able to see some changes were recently made for devices that go directly into enable mode for CSPC 2.7.2 which may help solve your issue. When you run your SNTC Collection profile, do you know if the CLI Commands for a device showing the error are still being collected?
Thank you,
Jarrett
I've updated and am now running 2.7.4, so we'll see.
That did not work - I still have the same devices showing "Failed to verify Enable Password".  Does this affect accurate and complete data collection?  And in any case, how can this be corrected?
"When you run your SNTC Collection profile, do you know if the CLI Commands for a device showing the error are still being collected?"
There appear to be 15 CLI commands that are being run.  What I see is (and there should be a way to run this as a report):
1. show running-config             Successful
2. show startup-config              Successful
3. show ap summary                 Not Applicable
4. show ap inventory all             Not Applicable
5. show c7200                          Not Applicable
6. show diag                             Integrity Check Failed with the Condition: does not match the expression ^%\s*Incomplete
7. show gsr chassis-info           Not Applicable
8. show hardware                     Not applicable
9. show idprom all                    Successful
10. show inventory                   Successful
11. show module                     Successful
12. show rsp chassis-info        Not Applicable
13. show version                      Successful
14. show version brief              Not Applicable
15. show version system          Not Applicable
That is the complete list of CLI commands that this collection profile is attempting to run.  "Not Applicable" error messages always show that the command is "not applicable to this device".  I'm presuming looking at this that this means that the commands are being properly run and that the error message of "Failure to Verify Enable Password" does not reflect an actual error in data collection or processing?
