Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
I have multiple inventory collection delta reports for different customers where their "summary" downloaded page is blank (showing all "0"s) for added, deleted or changed inventory. Both snapshot uploads timelines are valid and have data. Can you help figure out why the data is blank in summary screens? The customer did make inventory changes and it's not showing up.
Thanks!
Solved! Go to Solution.
Hello Craig,
Can you try generating inventory delta report now and let us know the results? The team has provided a fix last night.
Suchita
Hello Craig,
We are aware of the issue and I am working with Engineering to help resolve the same. In the meanwhile you may want to try requesting report through different browser and see if that helps.
Suchita
Thanks Suchita. Other browsers are not working. Can you please reply back to this post once the report works so I can rerun them?
Suchita,
Is there a resolution on this? It seems some customers this works for and others it doesn't. I'm just ran a new delta report for my customer, and I get all "0" listed on the report findings when running upload dates from January 2019 to April 2019. Can you assist to fix this report? PM me if you want details on the customer and inventory
Craig
Is there an update on this? I cannot use this report for any customers right now since the data is "blank" on the summary. Please help. Thanks!
Hello Craig,
Apologies for the delay. Our Engineering Team is working on resolving this issue.
You can track the progress via bug CSCvp60286.
Suchita
Hello Craig,
The team has fixed the bug CSCvp60286. Please give it a try now and let me know if you see any issues.
The bug status will be updated shortly.
Suchita
Since not working for one of my customers. The upload was from 6/11/19. PM me if you want details for validation on your side.
Hello Craig, Please send me the details via private message.
PM sent
Hello Craig,
I was able to reproduce the issue, and have reopened the bug CSCvp60286.
I will work with Engineering Team to get this resolved at the earliest.
My apologies for the inconvenience this may cause to you.
Suchita
Hello Craig,
Suchita
works now. Thanks!
