03-08-2012 03:00 PM
Hi all,
I know that in some NX-OS versions we need to manually set some default system-qos policies in order to make FCoE to work on Nexus 5500UP:
switch(config-sys-qos)# service-policy type qos input fcoe-default-in-policy
switch(config-sys-qos)# service-policy type queuing input fcoe-default-in-policy
switch(config-sys-qos)# service-policy type queuing output fcoe-default-out-policy
switch(config-sys-qos)# service-policy type network-qosfcoe-default-nq-policy
Is it really needed the configuration above or is it automatically set?
After writing these settings, I started getting this error message on the upstream switch (two Nexus 7000) connected to my 5500 through a vPC:
2012 Mar 6 17:59:48 N7K %$ VDC-1 %$ %IPQOSMGR-2-QOSMGR_DCBXP_PFC_CMP_FAIL_MSG: Ethernet3/9 - qos config 'Priority-flow-control' not compatible with the peer
ethernet 3/9 is a vPC member.
I don't know if:
- the system qos above is not needed
or
- I have to set something on upstream Nexus 7000
Thank you all who want to help me.
Max
03-13-2012 05:25 PM
Hello Max
In 5.1(3)N1(1) and later, once you enable "feature fcoe" the QoS gets automatically applied and in earlier releases you will need to do it manually.
Will you be implementing FCoE on Nexus 5500? If so, then yes you will need the QoS configuration.
03-14-2012 01:56 AM
Hi, thank your for your answer.
I actually already enabled the system qos manually since we run 5.0(2)N2 release.
We will implement FCoE over 5500. What I'm worried about is the warning message I posted above on Nexus 7009s connected to my 5500s after I enabled the system qos.
Could it be originated by the DCBX feature? May I have some problem if 'Priority-flow-control' setting between N5k and N7k don't match?
