06-24-2014 07:46 AM
Im trying to setup an EtherChannel between my 3750 stack and my 2960S stack.
I have 2 3750x in stack form. (2 switches).
I have 4 2960s in stack form. (4 switches).
I need to create a 2GB channel between them. My core is the 3750, and my 4 stack 2960s is on another floor, so I want to create a 2GB pipe between them.
I know you can create a PO between them, but what I want to do is create a 2GB pipe between them that run at the same time, active on both 1GB ports.
Is that possible and how? This is my current setup so far:
Switch Stack 3750
interface Port-channel10
description ETHSW04-1.5
switchport trunk allowed vlan 1,210,220,214,216,220,306,406
switchport mode trunk
snmp trap mac-notification change added
snmp trap mac-notification change removed
spanning-tree guard loop
spanning-tree cost 15
interface Port-channel11
description BRP-Uplink to ETHSW04-1.5
interface GigabitEthernet1/0/39
description Uplink to ETHSW04-1.5
channel-protocol lacp
channel-group 10 mode active
interface GigabitEthernet1/0/40
interface GigabitEthernet2/0/39
description Uplink to BRP-Uplink to ETHSW04-1.5
channel-group 11 mode active
interface GigabitEthernet2/0/40
Switch stack 2960s
description Uplink to CORE01
interface Port-channel2
description BRP-Uplink to CORE02
interface GigabitEthernet1/0/47
description CORE1-G1/0/39
channel-group 1 mode active
interface GigabitEthernet1/0/48
description CORE1-G1/0/40
interface GigabitEthernet4/0/47
description BRP-CORE2-G2/0/39
spanning-tree portfast
channel-group 2 mode active
interface GigabitEthernet4/0/48
description BRP-CORE2-G2/0/40
Thanks...
Solved! Go to Solution.
06-25-2014 10:17 AM
Not possible AFAIK.
LACP will provide load balancing and redundancy which is pretty good for most use cases.
Other then that, you would have to look at 10GB uplinks between switches for more bandwidth.
