12-12-2014 02:28 AM
Hi all
I'm wondering if other users have massive problems with their SG500XG-8F8T gear as well?
When we first installed them and added them to the stack of another two SG500X-24P switches (so 2x SG500X-24P & 2x SG500XG-8F8T), we saw fatal errors and the whole stack crashing on a regular base.
Upon advice from Cisco, we split the stacks into two separate Stacks with the SG500X-24P's in one stack, and the 2x SG500XG-8F8T in another stack, connecting them together using redundant LACP trunk ports.
However, we currently keep losing the connection with both ports dropping out of the Trunk. Cisco was/is looking into this issue, but we haven't got any further in the last week or two.
Does anyone else have such problems as well? Do we have two "monday-models" of switches?
We're seriously considering getting a refund for them, they are unusable in their current state :(
Michel
01-19-2015 02:21 AM
Hi Michel,
Sorry to hear about the issue that you are experiencing. I followed up with the support team and was informed that they opened the following bug case CSCus44862 regarding your issue.
You can track the bug fix development here: https://tools.cisco.com/bugsearch/bug/CSCus44862
Cindy
01-19-2015 05:28 AM
Thanks Cindy
Two comments about that:
- Could you link our case to the Bug: SR 632714595
- Is it possible to up the severity on that bug? The switches are completely unusable for us like this. They are just sitting there doing nothing currently!
Michel
01-20-2015 12:18 PM
Hi Michel,
One of our escalation engineers will update you.
Cindy
02-04-2015 10:22 PM
Hi Cindy
Unfortunately, this has not happened yet. We just had to reboot the switches again because they started miss-behaving :(
They are still unsuable for us :(
Michel
02-05-2015 11:24 AM
Hi Michel,
I am sorry that one of our escalation team members didn't contact you.
Can you please private message me your email address.
Cindy
02-11-2015 08:44 AM
Is there anything that I can do to get a fresh pair of switches as an RMA to see if that helps? We have the units since November and still can't use them because they crash our Network. They are currently rotting in our Datacenter.
I'm not happy with Cisco support.
02-19-2015 08:26 AM
Hi Michel,
I was informed by the Cisco Small Business Support Center that your RMA has been processed and they have contacted you with further instructions.
Thank you for your patience and understanding.
Cindy
02-20-2015 07:52 AM
Hi Cindy
Yes, we are getting replacements, and see if this solves our issue. Thanks for your help
Michel
03-17-2015 08:09 AM
I am considering this exact hardware configuration for an end client. I would like to know if there was a resolution to the issue, and if that resolution "solves" the problem. I do not want to deploy hardware that is "fragile".
03-17-2015 08:13 AM
Hi Larry
Unfortunately, the replacement of the switches did not resolve this issue, it remains. :(
We are still looking for a solution, the latest what we tried is to replace the cables that were used to connect the 2 stacks together. I have yet to change the traffic flow again to be able to see a result, but I'm currently on a business trip, and don't want to risk that while I'm away :)
03-17-2015 08:17 AM
Thanks for the quick reply. I hope it proves to be cables for your sake.
03-19-2015 12:27 PM
Hey Micheal, I am told by Cisco that this issue was addressed int he latest firmware 1.4.0.88 and I am wondering what firmware level you are running on your switches because I don't see it listed in this thread. Also the boot levels need to be upgraded as well I am told. Thanks in advance for the update.
03-20-2015 12:13 AM
Hey Larry
We have been running 1.4.0.88 all time long.
/Michel
04-03-2015 04:46 PM
Hi Michel
Same problem with my stack:
Current stack mode is : advanced-hybrid-XG
Topology is Ring
Stack image auto synchronization is enabled
Unit Model Name MAC Address Software Master Status
1 SG500XG-8F8T b0:00:b4:57:3e:b1 1.4.0.88 Enabled master
2 SG500XG-8F8T 34:db:fd:89:f3:5e 1.4.0.88 Enabled backup
3 SG500X-24P d4:d7:48:d0:4c:ee 1.4.0.88 Disabled slave
4 SG500X-24P d4:d7:48:d0:4d:9c 1.4.0.88 Disabled slave
Any solution for this issue?
Regard,
Helder Coelho
