Id like to set up our AP to push our different vlans depending on which ESSID you connect to.
A few things I am unclear on.
The switch port on the SGE needs to be in trunk mode I assume.
Do I marry the Management Vlan ID on the AP to the PVID on the SGE port ?
Or is the PVID the untagged vlan ID ?
I set the switches port to trunk mode, it's PVID to 10 and set the management vlan ID on the AP to 10 and I get TTL Exceeded in Route when I try to ping.
