09-26-2014 10:27 AM
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about Voice VLAN on Small Business switches with Cisco subject matter expert Aleksandra Dargiel.
In particular, Aleksandra will cover topics such as Smartports Macro, OUI based Voice VLAN, design and implementation with other Cisco infrastructure devices
Aleksandra Dargiel, CCNP S&R is a Subject Matter Expert in Cisco Small Business. She spend 4 years in STAC supporting Small and Medium Business customers and partners. 6 years hands on experience and lateral thinking allows her to drive resolution of complex technical problems.
Remember to use the rating system to let Aleksandra know if he has given you an adequate response.
This event lasts through October 8th, 2014. Visit this forum often to view responses to your questions and the questions of other Cisco Support Community members.
10-02-2014 08:56 AM
Hi there..
I have a question..
Is it better to use Telephony OUI or auto Voice VLAN on SG200?
10-03-2014 02:33 AM
Hi Sarah,
Thank you for starting the discussion :-)
If you have Cisco phones supporting CDP than the most seamless solution would be Auto Voice VLAN.
However if you are using 3rd party phones which do not support CDP you have to:
1. either add phone MAC address to OUI table so switch would treat its traffic as the Voice VLAN traffic
2. or simply configure phone to start tagging traffic with Voice VLAN ID
Please note: With the OUI Voice VLAN solution there will not be tagged traffic between the phone and the switch while with Auto Voice VLAN phone is told by switch to start tagging its traffic.
Aleksandra
10-03-2014 08:28 AM
I would add that many phones support LLDP also and can use auto voice VLAN like a Cisco CDP phone. I have even seen some non Cisco phones that have CDP (NEC DT700).
Interesting point about OUI Voice VLAN. So really the phone sits on the native VLAN with no tagging, but the switch passes traffic from its MAC address to voice VLAN, I guess?
10-03-2014 10:35 AM
Hi Brandon,
Yes, ..."When the device is in Telephony OUI mode and a port is manually
configured as a candidate to join the voice VLAN, the device dynamically
adds the port to the voice VLAN if it receives a packet with a source MAC
address matching to one of the configured telephony OUIs. An OUI is the
first three bytes of an Ethernet MAC address. "... admin guide page 212
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
Aleksandra
10-03-2014 07:41 PM
Hi Aleksandra
I have noticed several times , the phone is working even without tagging traffic Voice VLAN ID' ,
i saw this on 3560x switches , why does it works ?
eg : sw mo access
sw access vlan 10 ( vlan 10 is not voice vlan ) , and see there is no voice vlan tag
10-04-2014 01:10 AM
Actually Voice VLAN is active only on the access ports. It is dynamic VLAN and trunk is only operational when phone is present on the interface.
So to answer to your question voice vlan is most configured globally and enable on the interface. Port is regular access port when workstation is connected however when phone is plugged in and detected by switch. Switch would instruct (via CDP) to start tagging phone traffic and operation status of this port would be actually trunk.
you might verify this by checking show mac address-table. This is very useful command when trying to identify operational status of the ports.
I hope it sheds light on the subject.
Aleksandra
10-04-2014 02:03 AM
HI,
The port is an access port . And Normally when i configure the access port as below
interface GigabitEthernet3/3
switchport access vlan 10
switchport mode access
switchport voice vlan 8
And once i forget to add ' switchport voice vlan 8' and the phone (6941)connected
it started to work !!
10-04-2014 02:14 AM
This is not something I have seen before but was the phone actually in the default settings? and how exactly did you check this?
Aleksandra
10-08-2014 08:12 AM
Hi Aleksandra, good morning!
I'm having a problem with Lucent IP Phones in my network. They randomly reboots even in a middle of a conversation.
The phone provider claims that is a switch configuration issue.
It's a SG300 24P
Marlon
10-13-2014 11:16 AM
Hi Marlon,
It would be good to get syslog from the phone to understand the reason. You can also check if the same issue would be present if the phone is on the port configured as access. Do you have any enterprise devices on the network such an ASA.
Aleksandra
10-13-2014 11:34 PM
Hi Marlon,
there are many various reason the IP phone would reboot starting from physical layer up the OSI model. If you suspect any problem with switch you can open ticket with Cisco Small Business Support team:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
10-08-2014 11:58 AM
We have a Cisco RV220W Router/Switch and a Matrix phone system.
All of the internal phones are on the LAN while we also have external phones connect to a One-to-One NAT for the VOIP System which is connected to a T1. The external bandwidth that is being used is only by the external phones connecting through the internet routing through the VOIP system (Eternity Matrix) and then going through the T1.
We also want to prioritize LAN traffic for for SIP based phones so if there is internal congestion the phones are prioritized. Since it is a Gigabit switch this is less of an issue.
We got a Netgear Smart Switch which isn't configured at the moment other than provide PoE for the phones. The model is GS752TPS. I know this could be configured some on that Switch but would rather keep it a "dumb" switch and let the Small Business Router handle as much as possible for VLAN assignments and/or QoS.
Danny
10-13-2014 11:29 AM
Hi Danny,
If the router is a "bottle neck" then it makes sense. However RV220 would only handle how the queues are emptied and not remarking. Is this the question?
Aleksandra
10-13-2014 11:32 PM
Danny,
It would be good idea to open this post in the Small Business Router section.
Aleksandra
