Backup and Restore question
yahyaa.bham
Hi all
possibly a simple question. I have 5 SG500 switches. 4 are currently configured as a Stack and in production. 1 is spare and that i use for test.
On the spare one, I have configured vlans, and interfaces and all the settings the way i would like for my network. under system mode, it has been set to L3, stack master is unit one and unit 1 is forced to be stack master.
Can i simply backup this switch, and restore it onto the master switch within the stack?
My main concern is, will it work, as i am going from a single switch to a stack of 4.
Will all the ports simply be set to the default vlan?
Is there anything else i should consider?
Thanks in advance
0 Replies 0
