Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2943 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4534 Views
  • 1 replies
  • 16 Helpful votes
How is one supposed to upgrade an SG-300-52 from 1.3.0.62 to current? The release notes for 1.4.7 say: Upgrading from Versions Earlier than 1.3.5When upgrading the device from version prior to 1.3.5:    • For Sx200/Sx300 models, first upgrade the dev...
Resolved! SF300-24P upgrade
I have a SF300-24P Small Business switch with old firmware (1.1.2.0 and 1.1.1.0.6 boot) which I want to upgrade to the latest versions. The release notes say that prior to going to 1.4.7.5, if you are earlier than 1.3.5 you need to do an interim step...
My company has been having a few issues recently where SG300-28A switches 'go dead' to field locations. When they arrive back to us we take a look at them and are prompted for the MAC address, serial number, and hardware version. After a lot of fight...
rkendrick by Level 1
  • 1562 Views
  • 2 replies
I have a question, if I configure a SPAN session on a pair of Nexus 5500's in which the source is a server plugged into a FEX, and the destination is a server plugged into each of the 5K's via a 10gig breakout port (the default ports on these 5K's be...
I have setup a link aggregation between 2 Cisco SG300 network switch. I had assign port 1 and port 2 (both are Gigabit port) as a member of LAG1. From the Cisco switch GUI,it is shown that the both port is an active member. In this case, will the LAG...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
