Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3717 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5401 Views
  • 1 replies
  • 16 Helpful votes
I need an IPv4 for each VLAN, but ich can't set up them. In the german manual is written that the switch must be in Layer 3 Mode. But nowhere is wirtten how ti switch between layer 2 and layer 3 mode. So, how can I change the mode?
Hello,I have two serie 300 switches with 4 vlans created. I normally have one connection between two switches and configured as trunk mode with vlans added to that trunk.Now i want to have a new connection so it will have two links between each other...
Hello,I´m a IOS CLI fanatic. Its the first tiem that I have to configure a SB switch. Its very confusing, I want setup a voice vlan id as 200. but I don see that this value change when I try to apply the smartport macro to the interface.Its possible ...
We are replacing some netgear switches with the Cisco SG200.  The situation is relatively straightforward.  We have a series of VLAN's coming in on a trunk from a service provider for our Metro Ethernet locations.  These trunks then get cross-connect...
robbosch by Level 1
  • 4810 Views
  • 11 replies
I need a switch that does not have nickel plating, which some RJ45 connectors have. the SF100D-16 appears to have black RJ45 jacks, which would point to a non-nickel plating. does anyone know what material the RJ45 connectors and housing are made of?...
I can access the switch OK using http and have enabled telnet. However, when I telnet to the switch, I just get the                              Switch Main Menu                               ================                         1. System Configu...
britpgj21 by Level 1
  • 1972 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
