Can the cisco SF-302-08 switch support Inter-valn routing
I have two switches where layer 3 mode is enabled on both. I have created two VLANs (10 and 20) on the two switches and configured a static route to reach each VLAN. And then assigned the VLANs to Switchports but I am still unable to let the two different VLANs communicate with each other.
Is the Inter-VLAN routing supported on this type of switch without the need for a router device?
Thank you in advance.
marce1000
                      - Guess it should work ,
  Ref : https://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
  >...Static routing/Layer 3 switching between VLANs:...
IPv4 routing
Wirespeed routing of IPv4 packets
Up to 512 static routes and up to 128 IP interfaces
Could you kindly share a guide or direct me to a resource that provides comprehensive instructions for configuring the two switches to enable successful inter-VLAN routing? Your assistance in this matter would be greatly appreciated.
