Can the Cisco SF302-08 switch support IP routing capabilities?
mema7261
I'm currently working on configuring inter-VLAN routing on a Cisco SF302-08 switch. I've already enabled Layer 3 routing, created the VLANs, assigned them to switchports, and configured the switch VLAN interfaces accordingly. However, I'm encountering difficulties at the step where I need to configure a routed port or a static route. Despite attempting these configurations, I'm unable to achieve successful communication between the different VLANs.
The switch's configuration:
show running-config:
v1.4.0.88 / R800_NIK_1_4_194_194 CLI v1.0 set system mode router
! vlan database vlan 10,20 exit
interface vlan 1
ip address 101.205.25.252 255.255.255.0
no ip address dhcp
interface vlan 10
ip address 101.205.10.1 255.255.255.0
interface vlan 20
ip address 101.205.20.1 255.255.255.0
interface fastethernet3
switchport mode access
switchport access vlan 10
interface fastethernet4
switchport access vlan 20
interface fastethernet5
switchport trunk allowed vlan add 10,20
interface fastethernet7
interface fastethernet8
exit
ip route 101.205.10.0 /24 101.205.25.254
Consequently, I am seeking assistance to resolve this issue. Any guidance or support offered would be greatly appreciated.
pieterh
the router config seems ok,
but do you have fixed IP-address configuration for your clients?
if not where is your DHCP server located ?
-> you need an ip-helper address configured on the vlan's/ SVI's that are not directly connected to the DHCP-server vlan
Cisco Small Business 300 Series Command Line Interface Guide Release 1.2.5/1.2.7
37.14 ip helper-address
Thank you for your response.
I've set up static IP addresses for all clients in the network. Although I appreciate your suggestion about using an ip-helper address, I'm curious if it would still be beneficial given that the fixed IP configurations already in place.
If DHCP is not used, then ip-helper is not needed / will not improve the routing behavior
what unsuccessful communications are you talking about ?
NB! the windows firewall by default only allows incoming trafic from the local subnet
so it will not allow icmp/ping or remote-desktop connections from another subnet
-> you need to modify the windows firewall configuration,  (or simply disable temporarily  to perform your tests)
