11-08-2022 07:46 AM
Dear all
I would like to buy some CISCO switches of the type CBS220-48T-4G 52 Port.
This switch does have 4 SFP ports.
What I couldn't find out is if the 4 SFP ports are dual-purpose ports, which would allow me to connect clients to the SFP ports or if the SFP ports can be used for uplink only.
In the manual and datasheet I couldn't find my answer.
Does anyone have such a switch and does have the answer?
Many thanks
Solved! Go to Solution.
11-08-2022 08:05 AM
you can use for uplink also you can use for end device connectivity if required to use.
11-08-2022 08:05 AM
11-08-2022 10:41 PM
Thanks a lot Balaji for your reply.
