CBS350 web interface unresponsive
ambarr
I have a stack of 3 CBS350-48T-4X switches where the web interface is now unresponsive.  The "processing data" status indicator gets no further than 50%, and I'm unable to get into the configuration screens. Initially I was able to get into the web interface but, for some reason it stopped working.
ambarr
After powering down the 3rd member of the stack, the web interface became accessible again.
21 Replies 21
@ambarr can you try different web browser
Good luck
KB
I tried 3 different browsers, none worked.
marce1000
 - Some hints : 1) Check logs on the device
                        2) Have a reboot
                        3) Use the latest firmware available ,
 M.
Yes, rebooted and using latest firmware. How do you check firmware using cli?
Sorry. I meant how do you check logs using cli?
           >...Sorry. I meant how do you check logs using cli?
           Use the show bootvar or  show version command(s)
 M.
server-room-stack#show bootvar
Active-image: flash://system/images/image_cbs_ros_3.3.0.16_release_cisco_signed.bin
Version: 3.3.0.16
MD5 Digest: 7decdf94fd5999afb7b07509896c693b
Date: 23-Mar-2023
Time: 11:37:54
Inactive-image: flash://system/images/image1.bin
Version: 3.2.1.1
MD5 Digest: 937212ebf51de43330b6f7967a7445ae
Date: 13-Feb-2023
Time: 01:12:59
server-room-stack#show version
Version: 3.3.0.16
Date: 23-Mar-2023
Time: 11:37:54
Version: 3.2.1.1
Date: 13-Feb-2023
Time: 01:12:59
  >...Active-image: flash://system/images/image_cbs_ros_3.3.0.16_release_cisco_signed.bin
    Firmware is latest , as   a sanity check , you could you  try from another 'workstation' (PC or other) ?
 M.
I've tried access it from 3 different machines all with different OS's
        - What is the network topology and involved devices between the PC and the CBS350 ?
 M.
I've tried both directly attached and with another switch between.
                                - >I've tried both directly attached and with another switch between.
   Use  another switch in between  , then verify a couple of things : make sure both your own connection and the remote CBS350 have full-duplex (port setting and negotiated) , also check the port speeds anything such as 10Mb or below , is an error. Also check the port counters for both your PC and the CBS350 , make sure that there are no error counters incrementing ,
 M.
Verified no errors and full duplex on both connecting trunk ports. Still can't get into web config.
     >...Verified no errors and full duplex on both connecting trunk ports. Still can't get into web config.
 - Don't use trunk ports for the configuration phase , use access mode only , both for your device and the cbs350 ,
 M.
