CBS350
shuja Tahir
I have CBS350, facing issues some access ports automatically a member of the trunk port. Does anyone know the solution?
balaji.bandi
that screenshot not show much information, can you post show run to look, what is configured.
BB
KJK99
Level 3
Level 3
@shuja Tahir
I'm not really sure what you mean, but you may like to check the switch's Smartport settings. When the Smartport feature is enabled, the switch applies to the port one of the defined macros that can turn an access port into a trunk port. If you do not need that feature, just disable it.
Kris K
