01-26-2022 09:26 AM
I got a new 220-8T-E-2G switch today and came across a strange issue.
I have logged in to the WEB UI the first time and changed the default password to something non-standard.
Once I click "Save" the Web UI logs me out automatically and brings me back to the login screen.
When I then try to login with the new password just set, it does not accept the new password. I only get this error:
It also does not accept the standard user and password cisco / cisco anymore. So it must have updated the password internally, but does not allow me to login.
When resetting the switch I can login with cisco / cisco again, but obviously the issue starts from scratch again.
I have tried various passwords with and without special symbols. But even a pretty basic password with only uppercase, lowercase and numbers shows the same behaviour.
This is the device and firmware version:
Cisco CBS220-8T-E-2G 10-Port Gigabit Smart Switch
2.0.0.13
Any advice what could be wrong here ? Is there a known bug in this firmware version perhaps ?
Obvisouly I can't update to a recent firmware without access to the UI.
01-26-2022 09:38 AM
You need to reset to factory and start over again :
Look at the password guidelines : ( make sure check the keyboard layout, before changing password type same notepad is the one changing correct)
01-26-2022 10:14 AM
I did a factory reset a couple of times already but that did not help.
The new password is also according to the password guidelines, which are (according to the GUI):
Please change your password from the default settings for better protection of your network
• Cannot be the same as the user name.
• Cannot be the same as the current password.
• Minimum length is 8.
• Minimum number of character classes is 3.
I used cut&paste for the password when setting as, as well as when trying to login, so keyboard layout cannot be the reason for this.
04-13-2022 06:17 AM
Hi Balaji
I have also tried a factory reset to no avail.
Is there a fix for this issue yet?
I have reset the password and having the exact same issue.
Thanks in advance
Aled
04-13-2022 07:44 AM
raise an SMB Tac case to investigate for you.
04-14-2022 06:12 AM
Thanks BB. How does one go about raise an SMB Tac Case please?
Cheers
Aled
04-14-2022 08:38 AM
04-14-2022 09:27 AM
Hi All
Thanks for the advice on raising the SMB TAC ticket. I spoke with an engineer who advised that when being prompted to change the login credentials that it's important to change the username as well as the password. I did this and it now works!
Thanks again
Aled
04-14-2022 09:52 AM
Glad all good and works as expecte, and thank you for sharing the information with us. so we mark as resolved here.
09-27-2022 12:06 PM
On the first login, you have to change not only the password but even the username. Don't use cisco as a user, change it.
