09-03-2018 07:07 AM
Hy everybody.
I have a cisco rv325 ans a cisco 2960.
I will need to access to my switch from another vlan and,if possible, from outside LAN.
i have created a vlan in the switch specially for this.
i can access ssh when i use the port which is in this vlan.
but from another vlans i can't.
Can somebody help me :) ?
Here my configuration :
Switch-Cisco#sh conf Using 5280 out of 65536 bytes ! version 12.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Switch-Cisco ! boot-start-marker boot-end-marker ! enable password XXXXXXX ! username admin secret 5 XXXXX username domoticity secret 5 XXXXXXXXXXXXXXX ! ! aaa new-model ! ! aaa authentication login default local ! ! ! aaa session-id common system mtu routing 1500 ip dhcp excluded-address 192.168.0.1 192.168.0.99 ip dhcp excluded-address 192.168.0.104 192.168.0.254 ! ip dhcp pool systeme network 192.168.0.0 255.255.255.0 dns-server 8.8.8.8 default-router 192.168.0.1 ! ! ! ! crypto pki trustpoint TP-self-signed-952440448 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-952440448 revocation-check none rsakeypair TP-self-signed-952440448 ! ! crypto pki certificate chain TP-self-signed-952440448 certificate self-signed 01 nvram:IOS-Self-Sig#3839.cer ! ! ! spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! ip ssh time-out 60 ip ssh logging events ip ssh version 2 ! interface FastEthernet0/1 description acces ssh switchport access vlan 101 switchport mode access ! interface FastEthernet0/2 description trunk vlan 2 domoticity switchport trunk allowed vlan 2 switchport mode trunk ! interface FastEthernet0/3 description trunk vlan 3 casa et multimedia switchport trunk allowed vlan 3 switchport mode trunk ! interface FastEthernet0/4 switchport trunk allowed vlan none ! interface FastEthernet0/5 description trunk vlan 5 domotique et camera switchport trunk allowed vlan 5 switchport mode trunk ! interface FastEthernet0/6 description trunk vlan 6 watchdog switchport trunk allowed vlan 6 switchport mode trunk ! interface FastEthernet0/7 description trunk vlan 7 telephonie switchport trunk allowed vlan 7 switchport mode trunk ! interface FastEthernet0/8 description reseau domotique camera switchport access vlan 5 switchport mode access ! interface FastEthernet0/9 description reseau domotique camera switchport access vlan 5 switchport mode access ! interface FastEthernet0/10 description reseau domotique camera switchport access vlan 5 switchport mode access ! interface FastEthernet0/11 description reseau domoticity switchport access vlan 2 switchport mode access ! interface FastEthernet0/12 description reseau telephonie switchport access vlan 7 switchport mode access ! interface FastEthernet0/13 description reseau telephonie switchport access vlan 7 switchport mode access ! interface FastEthernet0/14 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/15 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/16 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/17 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/18 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/19 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/20 description reseau casa multimedia switchport access vlan 3 switchport mode access ! interface FastEthernet0/21 description reseau telephonie switchport access vlan 7 switchport mode access ! interface FastEthernet0/22 description reseau stockage imprimante switchport access vlan 4 switchport mode access ! interface FastEthernet0/23 description reseau domoticity switchport access vlan 2 switchport mode access ! interface FastEthernet0/24 ! interface FastEthernet0/25 ! interface FastEthernet0/26 ! interface FastEthernet0/27 ! interface FastEthernet0/28 ! interface FastEthernet0/29 ! interface FastEthernet0/30 ! interface FastEthernet0/31 ! interface FastEthernet0/32 ! interface FastEthernet0/33 ! interface FastEthernet0/34 ! interface FastEthernet0/35 ! interface FastEthernet0/36 ! interface FastEthernet0/37 ! interface FastEthernet0/38 ! interface FastEthernet0/39 ! interface FastEthernet0/40 ! interface FastEthernet0/41 ! interface FastEthernet0/42 ! interface FastEthernet0/43 ! interface FastEthernet0/44 ! interface FastEthernet0/45 ! interface FastEthernet0/46 ! interface FastEthernet0/47 ! interface FastEthernet0/48 ! interface GigabitEthernet0/1 description trunk vlan 4 nas et imprimantes switchport trunk allowed vlan 4 switchport mode trunk ! interface GigabitEthernet0/2 description reseau stockage imprimante switchport access vlan 4 switchport mode access ! interface Vlan1 description vlan defaut ip address 10.10.10.1 255.255.255.0 no ip route-cache ! interface Vlan101 description Vlan systeme ip address 192.168.0.1 255.255.255.0 no ip route-cache ! ip http server ip http port 1080 ip http access-class 10 ip http authentication local ip http secure-server ip http max-connections 2 ip http timeout-policy idle 50 life 120 requests 100 vstack ! line con 0 line vty 0 4 access-class 10 in transport input ssh line vty 5 15 access-class 10 in privilege level 15 transport input ssh ! end
thanks in advance
Solved! Go to Solution.
09-08-2018 02:05 PM
You need lanbase and the correct SDM template applied.
This isn't required for what you are trying to achieve, I would simply configure a gateway.
Martin
09-03-2018 12:05 PM
What VLAN you created for this, from what IP address range you are not able to connect ?
i do not see any routing in your config.
09-03-2018 12:14 PM
09-03-2018 12:42 PM
I do not see route configuration done here, you need routing between switch and rv325 , what is other VLAN you failed to connect, what is the IP address you try to connect from to 192.168.0.1 ?
09-04-2018 04:39 AM
hy,
thanks again to answer me :)
the other ip address are : 192.168.2.0/24, 192.168.3.0/24 and 10.0.10.0/24.
09-04-2018 04:46 AM
Switch-Cisco#sh ip route ^ % Invalid input detected at '^' marker. Switch-Cisco#
hy again, :p
can we etablish route in the cisco 2960?
09-04-2018 07:16 AM
The 2960 is a L2 switch, although it can do basic routing with the correct software, hence you getting that error.
You would need to configure a default gateway (ip default-gateway x.x.x.x).
Martin
09-04-2018 11:07 AM
in addition to other post, if you have right image.
you can do below steps :
config t
ip routing - enable routing
ip route src-ip to destination - replace src-ip and designation ip or interface
09-04-2018 01:29 PM
hy
thank you for your help again.
But i don't manage to do your command :
Switch-Cisco(config)#ip routing ^ % Invalid input detected at '^' marker.
09-04-2018 02:03 PM
can you post show version.
09-05-2018 09:49 AM
09-08-2018 01:53 PM
09-08-2018 02:05 PM
Martin
09-08-2018 03:02 PM
