cisco 2960 access ssh from another vlan
domoticity
Hy everybody.
I have a cisco rv325 ans a cisco 2960.
I will need to access to my switch from another vlan and,if possible, from outside LAN.
i have created a vlan in the switch specially for this.
i can access ssh when i use the port which is in this vlan.
but from another vlans i can't.
Can somebody help me :) ?
Here my configuration :
Switch-Cisco#sh conf
Using 5280 out of 65536 bytes
version 12.2
no service pad
hostname Switch-Cisco
boot-start-marker
boot-end-marker
enable password XXXXXXX
username admin secret 5 XXXXX
username domoticity secret 5 XXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa session-id common
system mtu routing 1500
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp excluded-address 192.168.0.104 192.168.0.254
ip dhcp pool systeme
   network 192.168.0.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.0.1
crypto pki trustpoint TP-self-signed-952440448
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-952440448
 revocation-check none
 rsakeypair TP-self-signed-952440448
crypto pki certificate chain TP-self-signed-952440448
 certificate self-signed 01 nvram:IOS-Self-Sig#3839.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh logging events
ip ssh version 2
interface FastEthernet0/1
 description acces ssh
 switchport access vlan 101
 switchport mode access
interface FastEthernet0/2
 description trunk vlan 2 domoticity
 switchport trunk allowed vlan 2
 switchport mode trunk
interface FastEthernet0/3
 description trunk vlan 3 casa et multimedia
 switchport trunk allowed vlan 3
interface FastEthernet0/4
 switchport trunk allowed vlan none
interface FastEthernet0/5
 description trunk vlan 5 domotique et camera
 switchport trunk allowed vlan 5
interface FastEthernet0/6
 description trunk vlan 6 watchdog
 switchport trunk allowed vlan 6
interface FastEthernet0/7
 description trunk vlan 7 telephonie
 switchport trunk allowed vlan 7
interface FastEthernet0/8
 description reseau domotique camera
 switchport access vlan 5
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
 description reseau domoticity
 switchport access vlan 2
interface FastEthernet0/12
 description reseau telephonie
 switchport access vlan 7
interface FastEthernet0/13
interface FastEthernet0/14
 description reseau casa multimedia
 switchport access vlan 3
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
 description reseau stockage imprimante
 switchport access vlan 4
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
 description trunk vlan 4 nas et imprimantes
 switchport trunk allowed vlan 4
interface GigabitEthernet0/2
interface Vlan1
 description vlan defaut
 ip address 10.10.10.1 255.255.255.0
 no ip route-cache
interface Vlan101
 description Vlan systeme
 ip address 192.168.0.1 255.255.255.0
 no ip route-cache
ip http server
ip http port 1080
ip http access-class 10
ip http authentication local
ip http secure-server
ip http max-connections 2
ip http timeout-policy idle 50 life 120 requests 100
vstack
line con 0
line vty 0 4
 access-class 10 in
 transport input ssh
line vty 5 15
 access-class 10 in
 privilege level 15
 transport input ssh
end
thanks in advance
You need lanbase and the correct SDM template applied.
This isn't required for what you are trying to achieve, I would simply configure a gateway.
Martin
13 Replies 13
balaji.bandi
What VLAN you created for this, from what IP address range you are not able to connect ?
i do not see any routing in your config.
BB
Hy,
thank you for your answer.
the vlan for ssh is the 101
interface Vlan101
no ip route-cache
The tohers vlan is managed by the cisco rv325, with intervlan allowed.
I do not see route configuration done here, you need routing between switch and rv325 , what is other VLAN you failed to connect, what is the IP address you try to connect from  to  192.168.0.1 ?
BB
hy,
thanks again to answer me :)
the other ip address are : 192.168.2.0/24, 192.168.3.0/24 and 10.0.10.0/24.
Switch-Cisco#sh ip route
% Invalid input detected at '^' marker.
Switch-Cisco#
hy again, :p
can we etablish route in the cisco 2960?
The 2960 is a L2 switch, although it can do basic routing with the correct software, hence you getting that error.
You would need to configure a default gateway (ip default-gateway x.x.x.x).
Martin
in addition to other post, if you have right image.
you can do below steps :
config t
ip routing  - enable routing
ip route src-ip to destination - replace src-ip and designation ip or interface
BB
hy
thank you for your help again.
But i don't manage to do your command :
Switch-Cisco(config)#ip routing
can you post show version.
BB
hy :)
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960-48TC-S 12.2(55)SE12 C2960-LANLITEK9-M
Hy,
i have updated my ios :
* 1 50 WS-C2960-48TC-S 15.0(2)SE11 C2960-LANLITEK9-M
But same Problem :
Martin
Hy
Thank you, it works very well :)
