Cisco 3560X input errors on TenGigabit SFP-10GBase-LR
Wooldorf
Hi everyone. I have problem with enput errors on tengigabit port, and I  hope some of you will be able to help me undertand the reason of that.
cisco 4500 and cisco 3560 is connected via brand new cisco SFP-10GBase-LR with singlemode 2m patchcord. There is only one laptop connected to cisco 3560X. There is no overflow..! i
showinterfaces" showing input errors. also pinging of this switch (3560)  is not stable via those GIBIC connection. What can be a reason? did I miss some basic configuration ? Firmwares of both switches and service-module is up to date. other switches connected fo 4500 via Gbic doing well, but those all 4 are 1Gb uplinked, not 10Gbit.
TenGigabitEthernet1/2 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is fc5b.3985.e0b6 (bia fc5b.3985.e0b6)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 148/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:09, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
484923 packets input, 254472405 bytes, 0 no buffer
Received 275839 broadcasts (249466 multicasts)
173407 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 249466 multicast, 0 pause input
177258 packets output, 27866660 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Cisco-3560X_3#sh switch service-modules
Switch/Stack supports service module CPU version: 03.08.10.WAL
Temperature CPU
Switch# H/W Status (CPU/FPGA) CPU Link Version
1 OK 56C/45C connected 03.08.10.
13 Replies 13
Wooldorf
8% errorpackets
balaji.bandi
couple of things need to be checked --
reliability 148/255, txload 1/255, rxload 1/255  - check the reliability - this can cause many issue. SFP issue both the side need to check, also use 5meter OS2 cable and test it (LR means Long reach. so you see SFP get heated high, if you use short cables).
what is other side same output ? what you see errors ?
common input errors troubleshotting :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/12027-53.html#anc65
BB
Hi, thanx for your reply.
Gbics are : SFP-10G-LR-S CISCO 10GBASE-LR SFP+ 1310NM 10KM connected with 2m pachcord.
personally i have seen the issue -S and normal one. (this my experience, soon i use both the side -S or or just LR both the side works as expected)
make sure both the side either use -S or LR (you can not mix and it did not worked for me as i mentioned with my testings)
BB
Wooldorf
here are logs from 4500x site:
TenGigabitEthernet1/9 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet Port, address is 885a.92cd.8830 (bia 885a.92cd.8830)
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-LR
input flow-control is on, output flow-control is on
Last input 00:00:15, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 4000 bits/sec, 4 packets/sec
5 minute output rate 8000 bits/sec, 7 packets/sec
235847 packets input, 37249787 bytes, 0 no buffer
Received 68890 broadcasts (63296 multicasts)
1028134 packets output, 373400102 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
we do not see any issue on Cat 4K side,
Hope both the side cisco SFP ?
change the patch cable and check ?
reset SFP and reboot 3560 and test ?
can you post show run config on the port, check any duplex or other configuration applied ?
show controller x/x (from both the side )
BB
BOTH SFP are original brand new cisco (as wrote in intro)
Patchcable were replaced. It also have same issue when 3metters MULTIOMODE patchcord connected behavior is the same.
singlemode patchcord and multimode patchcorde hve the same result. Currently is correct singlemode patchcord applied.
Pinging switch via TE1/2:
Cisco-3560X_3#show running-config interface tenGigabitEthernet 1/2
Building configuration...
Current configuration : 124 bytes
interface TenGigabitEthernet1/2
switchport mode trunk
flowcontrol receive on
end
"check any duplex or other configuration applied ? " - all is default.
Transmit TenGigabitEthernet1/2 Receive
48060753 Bytes 263597086 Bytes
343244 Unicast frames 245003 Unicast frames
47021 Multicast frames 254256 Multicast frames
4546 Broadcast frames 27062 Broadcast frames
0 Too old frames 241653130 Unicast bytes
0 Deferred frames 19189260 Multicast bytes
0 MTU exceeded frames 2754696 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 183840 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 189708 Minimum size frames
0 8 collision frames 143834 65 to 127 byte frames
0 9 collision frames 16149 128 to 255 byte frames
0 10 collision frames 7576 256 to 511 byte frames
0 11 collision frames 8734 512 to 1023 byte frames
0 12 collision frames 160320 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
98264 64 byte frames 0 Valid frames, too small
249444 127 byte frames
18555 255 byte frames 0 Too old frames
15045 511 byte frames 0 Valid oversize frames
6132 1023 byte frames 0 System FCS error frames
7371 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
ASIC Rxbiterr Rxunder Fwdctfix Txbuflos Rxbufloc Rxbufdrain
ASIC0 0 0 0 0 0 0
ASIC1 0 0 0 0 0 0
ASIC2 0 0 0 0 0 0
Just give clarity is the both side SFP  ? SFP-10G-LR-S or one side SFP-10G-LR and another side SFP-10G-LR-S ?
3metters MULTIOMODE patchcord connected behavior is the same  - are you sure ? OM4 cable worked ?
for testing default the interface make Layer 3 P2P and check with pings ? (since we are not sure where is your Layer 3 interface here.)
Remove the patch cable :
default interface TenGigabitEthernet1/2  (other side also)
no switchport
ip address x.x.x.x 255.255.255.252
no shutdown
from switch to switch ping x.x.x.x and post the results  to identify the issue ?
BB
 are you sure ? OM4 cable worked ? - YES! orange cable multimode working same as new one yellow single mode. behavior was the SAME!
can you guys tell me what exactly it means: reliability 148/255
Cisco-3560X_3#sh inv
NAME: "1", DESCR: "WS-C3560X-48P"
PID: WS-C3560X-48P-E , VID: V06 , SN: FDO1834Z27R
NAME: "Power Supply 1", DESCR: "FRU Power Supply"
PID: C3KX-PWR-1100WAC , VID: V02L , SN: LIT18400DGF
NAME: "FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G SM Module"
PID: C3KX-SM-10G , VID: V01 , SN: FDO1705M0DN
NAME: "TenGigabitEthernet1/2", DESCR: "SFP-10GBase-LR"
PID: SFP-10G-LR-S , VID: V01 , SN: FNS19450MYC
Output
Command base-URL was: /level/15/exec/- Complete URL was:/level/15/exec/-/sh/inv/CR Command was: sh inv
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4500X-16 2 slot switch "
PID:                   , VID:      , SN: JAE17450FA4
NAME: "Supervisor(slot 1)", DESCR: "4500X-16 10GE (SFP+)"
PID: WS-C4500X-16      , VID: V02  , SN: JAE17450FA4
NAME: "TenGigabitEthernet1/1", DESCR: "1000BaseSX"
PID: GLC-SX-MMD        , VID: V01  , SN: OPM22410Z94
NAME: "TenGigabitEthernet1/5", DESCR: "1000BaseLH"
PID: GLC-LH-SMD        , VID: V01  , SN: OPM2232152Y
NAME: "TenGigabitEthernet1/7", DESCR: "1000BaseLH"
PID: Unspecified       , VID:      , SN: CIB131211207
NAME: "TenGigabitEthernet1/9", DESCR: "SFP-10Gbase-LR"
PID: SFP-10G-LR-S      , VID: V01  , SN: FNS19510289
as you can see, both SFPs are THE SAME, but error packets exist all the time. Both ports - on 4500 and 3560x were set to default now. but still problem exist.
Is there some basic configuration needed for SERVICEMODULE with SFP 10G ? i dont think so.., but iam beginer
yes we can see both have the same SFP module: I was suspecting maybe some bug on the 3560 side (this is a guess) - never seen this issue even though you mentioned replacing the cable.
what Logs do you see on both devices?
you have not shared the outcome after default the interface and configured layer3 interface and ping outcome - that is important here to understand here.
also, post below output from both devices.
#show idprom interface tenGigabitEthernet x/x
Also, check module information - see anything we missing here : ( also make sure IOS and module are up to date - you mentioned they are up to date, but not provided show version of switch 3560)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/net_mod_note.html
BB
Leo Laohoo
@Wooldorf wrote:
reliability 148/255​
Layer 1 issue.
Start by replacing the optics and the patch cords at both sides.
I have replaced GBIcs with another pair, and everything is ok now.
Thanx all of you guys ,aspecially to  balaji.bandi and Leo Laohoo
glad all good and our suggestion make you to fix the issue and can we mark as resolved
BB
