03-02-2012 01:50 AM
Dear All,
I am going to purchse SF 300 24p POE Switch and could anyone tell me if this Switch supports the configuration via console ?
As i have ESW-500 Sieries switches and it doesnot support console !
Please give me the answer for this question !
Thank you in advance !
Best Regards,
Giorgi
Solved! Go to Solution.
03-02-2012 05:45 AM
Hello Giorgi Ninidze,
Yes on firmware version 1.1.18 and above.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
03-02-2012 11:36 AM
Not everything a 2950 can do, because then why buy a 2950?
But it can do a lot. here is a link to the spec sheet.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10898/data_sheet_c78-610061.html
Randy Manthey
03-02-2012 05:45 AM
Randy Manthey
03-02-2012 10:58 AM
Randy, first of all let me thank you for your question.
Second, could you tell me if it could do everything like catalyst 2950 ? I mean does it support IP DHCP Spoofing, Private VLAN, Rapid-spanning tree and etc ... ?
03-02-2012 11:36 AM
Randy Manthey
03-02-2012 10:58 PM
Randy, Thanks, your answers was very helpful.
One more question and then we could close this topic.
Can i work via console in this switch ? I mean all kind of configuration i can do via consol or SSH ?
