Cisco SG220 config sntp
adeebtaqui
Level 4
Level 4
Can someone pls share their knowledge or experience in configuring sntp server for sg220.
I have anabe sntp server then added sntp server (internet) name as
sa.pool.ntp.org
Is it correct ?
5 Replies 5
balaji.bandi
thats valid NTP server, check is that your region and near by to your network? make sure your switch able to resolve the DNS names.
BB
@balaji.bandi
Hi ,  the manual time set is getting reset whenever i reboot of power off the switch.
I am saving config , even then time date resetting
once save the config, did you go back and see the config is saved as per your change.
check here for last steps to save the config.
BB
Hi Balaji,
You were right that as DNS not configured correctly the NAT website could not be resolved.
I change it to IP address and SNTP started working.
Kindly advise about DNS, what should I configure so as web names can be resolved. What should I enter in domain name system. There is no dedicated dns server, so shall I point 8.8.8.8
balaji.bandi
if you do not have any DNS Server - i use google DNS 8.8.8.8 or 8.8.8.4.4 to work.
BB
