10-20-2020 12:55 PM
Following the instructions in this link to try to get a backup of my start up config:
Seems simple enough: Select HTTP/HTTPS, select Backup, select Startup config. Click apply, and startup-config.txt starts downloading. Roughly 4k of data transfers and the screen changes to finished with no error message (Bytes Transferred:4160 Status:Copy finished Error Message: )
But looking at the downloaded file at the bottom of my browser window I see different errors depending on the browser. In the Chromium based Edge I see "Couldn't download - Network Issue". In Chrome its just "Failed - Network error". Firefox just says "Failed".
If I attempt to resume the download, I get an html documents that states:
Form is not defined
How do I backup my configs??
Solved! Go to Solution.
10-21-2020 01:08 AM
- Does it work when selecting other protocols such as tftp or scp ,
M.
10-21-2020 01:08 AM
M.
10-21-2020 11:43 AM
Not sure why HTTP fails, but TFTP worked. Thanks for prompting me to try something else.
