Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2907 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4489 Views
  • 1 replies
  • 16 Helpful votes
Please i need an urgent help. We have a primary number 81026888 in our organisation, when we forward calls from our internal DN to mobile number it alwaays show the primary number 81026888 but now it is showing 81026000, which is a number assigned to...
Hi there, Thanks for reading. I have SG220 switches which are cycling through blocking, learning & forwarding.  We've gone through the building and removed mini switches but the problem continues.  Here's what it's logging (and it repeats throughout ...
Hi! We run SG350X-48 in stack with SG350XG-24F in L3 mode. And we have issue with ARP table building. I dont see any problems in logs but ARP table building is wery slowly. If any host missing in ARP table and i do ping, it takes one, two or sometime...
nameless by Level 1
  • 364 Views
  • 0 replies
Hello, I have a sg300 and suddenly the manage vlan is not working.Please see my config below. the trunk interface is ge25the interface is up and running.  SG300-WAN#show runconfig-file-headerSG300-WANv1.3.0.62 / R750_NIK_1_3_647_260CLI v1.0set system...
it by Level 1
  • 845 Views
  • 0 replies
I have two SGE2000 switches - one PoE, one not - in a stack configured for Layer 3 mode. On the stack, I have a VLAN (5) configured and tagged for all ports on both switches. I want to assign an IP address to the VLAN interface that I can use for rou...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
