Bookmark
Subscribe
1678
Cisco SG300 / ASA 5505 intervlan routing issue
ciscoitzupport
Dear All
I have an issue with correctly configuring sg300 layer 3 switch behind ASA 5505 (incl Security Plus License)
The setup is as follows:
CISCO SG300 is configured as a Layer 3 Switch
Native VLAN 1: ip address 192.168.1.254, default route (inside interface ASA 192.168.1.1)
Extra VLANs on Switch defined
VLAN 100 with 192.168.100.0/24, default gateway 192.168.100.254
VLAN 110 with 192.168.110.0/24, default gateway 192.168.110.254
VLAN 120 with 172.16.0.0/16, default gateway 172.16.10.254
From the different VLANS(100,110,120)  I am able to connect to all devices in the other VLANS (except for Native VLAN 1; it's not pingable)
From switch cli I can ping my firewall (192.168.1.1) and all other vlan gateways and vlan devices (VLAN1,100,110,120)
From asa cli I can only ping my switch port (192.168.1.254), but no other devices in the other VLANs
My question is this. What do I need to change or setup in the switch or asa configuration in order for the other vlans to access the Internet through the ASA. I will not use the ASA as intervlan routing device, because the switch is doing htis for me
I tried changing the asa int e0/1 into trunkport (uplink port on switch also), to allow all vlans, but as soon as I do that I cannot ping to 192.168.1.254 from ASA cli anymore.
Any help is greatly appreciated
Edwin
Tom Watts
Hi Edwin, since the switch is in layer 3, the only needed behavior is to ensure the computer's default gateways are set to the SVI of the interface connecting to the switch to ensure the switch is forwaring the desired traffic to the ASA.
The configuration between the ASA and the switch should remain true per dot1q, such as native vlan untagged, all additional vlans tagged.
Also, if I'm not mistaken, on the ASA you need to set the port security level to 100.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Thomas
You were right I figured it out already
. I used the wrong ip address for gateway to the different subnets. It should have been the ip address 192.168.1.254 as I used 192.168.1.1 which is the ip address of the ASA itself.
I also made sure the uplink to ASA was configured as a trunk port and allowed 100,110,120
Thanks so much
