Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2068 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 6632 Views
  • 4 replies
  • 17 Helpful votes
HelloI have a Synology disk on port 4 on my SG300-10P switch and my computer on port 6 both on the VLAN 1, the only VLAN on my switch. Accessing this disk with the IP address is slow and data transfer to the disk is slow as well. So I traced the rout...
leostuder by Level 1
  • 1215 Views
  • 2 replies
(This question was originally posted as a document and copied over here.  The original question is located here: https://supportforums.cisco.com/docs/DOC-21712)My sd2008 switch keeps dropping the connection. If I replace the sd2008 with another switc...
cindy toy by Level 7
  • 1093 Views
  • 1 replies
                   i recently bought the sf 300-8 L3 switch and i noticed that the ACL rules are binded to ports and not vlans but what is the point of defining vlans if the rules i make belong to ports?if i have,lets say 20 ports to one vlan, i have...
crokkerrr by Level 1
  • 2351 Views
  • 9 replies
I am having a problem with 6941 phones on a SG300.When connected Smartport assignes the native and tagged voice vlan correctly, however the phone connects to the native vlan.  After running a few tests I have found it only happens when the voice vlan...
Hi,I would like to communicate between VLAN, with some access control. I will like gi1/1/2 to be able to communicate with gi1/1/14 but not gi1/1/13.Some background information:VLAN 200gi1/1/1 -> computergi1/1/2-> NTPVLAN 300gi1/1/13 -> computergi1/1/...
reginachh by Level 1
  • 5510 Views
  • 5 replies
Hi,There is a need to replace faster cisco switches.What I have at the minute is:uc500, esw520 and few 500 series switches which have only 2 1Gbit interface, the setup is like that connections from switch is going to cisco phone (vlan 150) and from p...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
