03-23-2013 04:13 PM
Im trying to recover the password from my stacked switchs(doing procedure on master switch),im following a guide i have read in this forum("SRW248G4 V1.1 unable to reset password"), at console terminal have chosen "password Recovery" it prompts the "current password will be ignored" and then i hit "Escape" the switch start loading de configuration, at this point i attempt to login from telnet or http but the login fails.
Here is the password/username combo im using (admin/blank ; admin/admin).
Is it possible to restore admin password or should i just hardware reset the switchs?
Solved! Go to Solution.
03-23-2013 04:21 PM
Hi Jose, when using the password recovery, it temporarily 'blanks' the password. When prompted for credential you should be able to hit your 'enter' key without typing anything.
-Tom
Please mark answered for helpful posts
03-23-2013 04:21 PM
-Tom
03-24-2013 06:03 AM
Hi Tom,
It worked, thank you very much.
04-06-2013 07:38 PM
From this document under "Limitations and Restrictions":
Mixing firmware versions in the stack is not supported. It looks like you should be able to upgrade the Linksys branded switches to the later versions of the firmware. From the same document, seems like you need to use the Easy Upgrade Utility.
Lost password go to http://www.recoverlostpassword.com
