Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 888 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5652 Views
  • 1 replies
  • 16 Helpful votes
Resolved! SG300 to RV180
I could really use some help. I just replaced my router (linksys wrt54G) which had everything working fine, but that is irrevelant since I have the RV180W now.This is what I'm trying to accomplish. I have the SG300 setup as a layer 3 switch. The IP o...
At the moment i have 2 internetconnentions with 2 different modems/routers. The computers are currently direct connected to the router.I'm considering adding a switch in the network and i hope i can make 2 different vlans each for one internet connec...
Romke1000 by Level 1
  • 669 Views
  • 1 replies
HiI want to configure VLAN on my SG-200-26P switchAP->Switch->RouterAP:VLAN's: 11,12,13Switch:Ports 13-18 connected to AP's, port 25 connected to routerRouter:on phisical intrface configured vilans:11,12,13on router I getting untagged frames, why?all...
luksusowa by Level 1
  • 825 Views
  • 4 replies
First of all, is there a document on the SG300 that explains everything in plain english?Here is what I am trying to do...I have a Charter Communications connection to the internet through their modem.This modem has a static IP.I would like to make t...
rkcooper by Level 1
  • 634 Views
  • 3 replies
Dear All,     I used two sf-300 switch and create 4 vlans and intervlan routing is working fine.Port 1 - 10                   -------------> Vlan 1Port 2 -20                   ----------------> Vlan 2Port 3 - 30                 ------------------> Vl...
I'm getting the following in the Flash Memory error logs. Also, the switch will lose its IP and HTTP/HTTPS management ability after the switch has been on a while. I've changed the date, but it never seems to save it, so ignore the date stamp.The run...
ian_guth3 by Level 1
  • 1960 Views
  • 7 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
