08-11-2015 06:48 AM
Hello everybody,
we are using in our monitoring system DNS records for switches, not long dns like
http://sw33.mgmt.domain.com/
after put Login credential, switch cannot login because
HTTP Header Field exceeds Supported Size
Cisco SB doesnt support DNS for login to switch?
Tomas
Solved! Go to Solution.
08-11-2015 08:29 AM
Try use firefox and try clearing cache in your browser , there's something about these switches supporting 512bytes only
08-11-2015 08:29 AM
08-11-2015 08:34 AM
Hi Mark
realy there was problem not with Cache but with Cookies, after delete Cookies working fine
Tomas
08-11-2015 08:45 AM
Good to know glad you got it sorted
