Configure a VLAN with an external router providing DHCP
Sputnik76
I'm a bit of novice at this but wanted some advice before I waste too much time.  I have a SG-350-28P and want to set up 2 VLANs.  One 'internal network' that uses fixed IPs for each device (10.0.0.XX) plugged into ports 1-14 and then a different network (ports 15-28) which is external facing in that I plug a 5G router into port 15 which will assign DHCP addresses to anything plugged into ports 16-28.   I want the two networks to be separated as VLANs.
Is the above configuration possible?
this is possible. make sure you configure correct VLAN for correct port set and vlan interface with IPs as required for internal and external networks for routing.
Good luck
KB
balaji.bandi
They not going to connect each other ?
This is switch, can not do any Routing (if you do not enable Routing mode of the device)
Both work Layer 2 (that is what you looking ?) - how about 10.X network to reach internet ?
BB
Jitendra Kumar
You can do one thing if you 5G router can configure the dhcp 10.0.x.x network and you can connect 2 separate links to the 2 router port on separate VLAN. then you can access internet on both VLAN.
Jitendra
