08-09-2019 11:07 AM - edited 08-09-2019 11:13 AM
have 2 sg300
following config on both gig 10 if:
interface gigabitethernet10
description Uplink
channel-group 1 mode on
interface Port-channel1
description Uplink
switchport trunk allowed vlan add 2-3
when patchcable (2 Pairs, pin 12, 36) is connected on both ports, nothing happen, no status
when i connect to other devices with the same cable, port operate within seconds as 100mbit port
same when i try on other switch ports on both switches... never got ports up and running....
thanks in advance
kaspar
Solved! Go to Solution.
08-09-2019 02:28 PM - edited 08-09-2019 02:36 PM
thanks
i fixed it...
according the guidelink you sent ( thanks @balaji.bandi) i was able to figure out that i have to configure speed like this:
description Uplink
speed 100
no negotiation
description Uplink
now its working... ;-)
08-09-2019 11:28 AM
here is the config ( make sure it admin up)
I know you have mentioned one of the port connected to device it was up on the port ? is this port part of port-channel ?
thanks
i fixed it...
description Uplink
speed 100
no negotiation
description Uplink
08-09-2019 03:11 PM
Glad it worked and helpfull, can you mark as solution now.
