SG500 5G SFPs
I'm looking to see if anybody has found any 5G SFPs that are compatible with the SG500 series switches.  I'm looking to upgrade the link between my two but this distance between them precludes using the direct attach stack cables.  As 5GBase-T SFPs are becoming more commonplace I was hopeful that somebody would have some experience.  I've heard that at least one person has tried the Aquantia AQS-107s (which are 10/5/2.5/1000/100 capable) but did not have success.
Sujoy Paria
Please refer the ‘Supported SFP/SFP+ Modules’ section on the below mentioned datasheet link to get the supported SFP module list on the Cisco Small Business 500 series Switches…
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/c78-695646_data_sheet.html
Also you may check the user guide link (page   17) provided below regarding the supported SFP modules on Cisco Small Business 500 series Switches, the link is as follows…
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/quick_start/en/500_Series_QSG_En.pdf
Note: Third party vendor SFP modules may or may not be compatible with Cisco 500 series Switches.
