Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3022 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4610 Views
  • 1 replies
  • 16 Helpful votes
Hi, I have a question about SG200 Switches and LAGs. I have two SG200-50 with actually firmware. Just I want to know two things about LAG in this switches. Firstly, what is the max. amount of ports, which can be configuerd in one LAG? Secondly, what...
info by Level 1
  • 820 Views
  • 1 replies
Hello, I have a switch SG200-26 26 port, it work, have firmware 1.4.7.6. some port work normally - is UP, bat for example port 12,24,11,23 if is connected server NAS QNAP 412 P || status port is Down , no UP, I haven't connection, if I connect other ...
laserbit by Level 1
  • 9353 Views
  • 1 replies
I have a SG300-28 in L3 mode feeding a SG200-08 which is working.  I decided to upgrade to a SG500X-24 switch so I could play with a routing protocol.  I have a trunk port between the SG500X-24 switch and the SG200-08 switch.  For some reason VLAN2 d...
Lee Cox by Level 2
  • 684 Views
  • 3 replies
Hey, "Join VLAN" in "Port VLAN Membership" seems completely broken. First, it does not even show the initially selected port (here I selected GE28 and it shows GE1). Even when I change it manually in the popup, it does not show any mode or available ...
jer0nim0x by Level 1
  • 1292 Views
  • 2 replies
Hello, I'm stuck with this scenario, I have read a lot of information on Internet but it doesn't work: I need to configure a second SSID only for guest access, isolated from LAN data: 2x Access Point Linksys LAPAC1750PRO Switch Cisco SG200-50p Route...
apena by Level 1
  • 4622 Views
  • 17 replies
We have an SG300-28P that is part of a vendor provided equipment stack in support of an elaborate audio and video system in a conference suite. I have read online here that ports 1-24 are POE, yet when I connect a Cisco CP 8961 phone into any one of ...
mrchongo by Level 1
  • 450 Views
  • 0 replies
Hi Team, WE have purchased SG500x small business model switch, In that user module there is support for VRRP and we configured the IP.But we are facing the issue of VRRP ip of configured switch ICMP is not working. Please help on this case for any ...
saumya by Level 1
  • 457 Views
  • 0 replies
I have no working knowledge of using a managed switch and looking for some guidance. Scenario: I have a Dell C6100 (2U server with 4 nodes).  Each node has it's own Public IP address and I have the server in a Data Center (co-location).  The patch pa...
kbaker by Level 1
  • 735 Views
  • 0 replies
Hello!! i a facing a certain problem and i would be grateful if someone could help me. as show in the network photo, my main switch is the dhcp server. i have many vlans configured on my network. the problem is that i created a new vlan for the voip...
akapatos by Level 1
  • 496 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
