Create Cisco SG350-20 default route to router
I am new here and need help creating a default route. I have a SG350 configured as follows:
I created 6 vlan and assigned them to ports (access/trunk etcIPv4 static routes).
Then under IPv4 Interface I set IPv4 routing to enable and assigned IP addresses to the vlan.
VLAN 17 172.16.1.3/24
VLAN 11 192.168.11.254/24
VLAN 12 192.168.12.254/24
VLAN 16 192.168.16.254/24
IPv4 static routes I created a default route:
0.0.0.0/0 net hop 172.16.1.2 metric 4
But no outgoing interface is created. But it should be VLAN 17. What am I doing wrong here?
I have solved it. The problem sat in front of the screen. I have configured the port incorrectly. The port was configured to access and not to trunk as it should be. Now everything works.
balaji.bandi
not able to understand this, what outgoing interface?
Have you connected another switch?
Switch to Switch connected and connection established with other switches you see that interface I guess.
BB
Why are using metric 4. If theres another route with metric 0, it will be prefered
Glad you were able to resolve and thank you for the feedback.
BB
