Delete/deactivate certain port options
Kvothe42
Hi there,
I tried to setup LAG and now one of my ports has a configuration, I cant remove.
lldp optional-tlv sys-name sys-cap 802.3-power-via-mdi
I dont know where I put a check mark for this to show up in my interface config.
Sadly our cbs350 doenst have the option to just reset the configuration using "default interface".
Any ideas?
Heres a quick look:
interface GigabitEthernet1/0/21
switchport mode trunk
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
flowcontrol auto
switchport trunk allowed vlan 1-3
KJK99
Level 3
Level 3
@Kvothe42
Switch the web admin to the Advanced mode. Go Administration>Discovery – LLDP>LLDP MED Port Settings. Select the port and edit. A window pops up where you can select/deselect optional TLVs.
If you can't find a certain setting, always make sure you have the web admin in the Advanced mode.
Kris K
KJK99
Level 3
Level 3
@Kvothe42
Kris K
