DHCP Server in multiple VLANs
verdura
I have a layer 3 switch (SG500) and I created VLANs in it.
I have a Microsoft DHCP server that I need to serve all my VLANs. When I plug in a PC in VLAN110 I cannot get addresses. If I put it in VLAN120 all works fine.
Part of the config is:
vlan database
vlan 10,100,110,120
exit
ip dhcp relay address 192.168.200.1
ip dhcp relay enable
ip dhcp information option
interface vlan 100
 name STUDENTS
 ip address 192.168.100.50 255.255.255.0
interface vlan 110
 name STAFF
 ip address 192.168.110.50 255.255.255.0
interface vlan 120
 name SERVERS
 ip address 192.168.200.50 255.255.255.0
interface gigabitethernet1/1/16
 description "PC1"
 ip source-guard
 switchport mode access
 switchport access vlan 120
interface gigabitethernet1/1/17
 description "PC2"
 ip source-guard
 switchport access vlan 110
interface gigabitethernet1/1/21
 description "DHCP SERVER"
 ip dhcp snooping trust
macro auto processing type host enabled
ip dhcp snooping
ip dhcp snooping information option allowed-untrusted
ip dhcp snooping vlan 100
ip dhcp snooping vlan 110
ip source-guard
ip default-gateway 192.168.200.254
I plug in a PC in gigabitethernet1/1/17 and I cannot get address.
Is there any command to see the DCHP requests?
Can you please help me?
ktonev
There is no command to see DHCP requests - you can do port mirroring on this port and have another port connected to a PC running Wireshark. This way you will be able to see all packets, DHCP negotiation, etc.
Have you tried to plug another PC/device in port 17?
Have you tried to configure another port in VLAN110 and see if you can receive an IP address?
Thanks for the answer.
I've  been overwhelmed with work and cannot do more tests. Probably next week I'll try again.
Thanks for the idea of port mirroring /Wireshark. I'll try it!
johndesgarennes
Level 4
Level 4
If you have dhcp snooping enabled you can do a "show ip dhcp-snooping binding" to see the dhcp snooping database. I also believe you need to enable Ip arp inspection if you want to enable dhcp snooping.
verdura
I had a problem in DHCP server...
All works fine now!
