DHCP SERVER ISSUES ON SF300-24P
kwanshe01
please can any body sow me how to enable dhcp server on cisco sf300-24p poe  switch when ever i click in enable dhcp i get the following message :
DHCP server cannot be configured. To enable the DHCP server, remove DHCP clients on all interfaces.
Hello kwanshe01,
I am sorry you are experiencing this issue.  To explain mostly likely what is occurring is that the switch does not have a Static IP address.  It either has gotten DHCP from your DHCP server or is on its default IP address.  If it is on the default IP address it is considered Dynamic and not static.
To fix the issue statically assign your switches IP address then enable the DHCP server.
Michael D.
If this post is helpful please rate or mark as correct.
ruwyatt
Hi - is the switch itself a DHCP client or does it have static IP addresses on it's VLAN interfaces?
Hello kwanshe01,
Michael D.
