Does cbs350 support port forwarding and NAT
adeebtaqui
Level 4
Level 4
Kindly advise which cisco 8 port switch can support port forwarding and NAT to give public access from Internet to secure server in office behind switch
balaji.bandi
cbs350 - not do any NAT, this is just switch.
Look for any RV - Models (bare in mind these go end of life soon)
https://www.cisco.com/c/en_uk/products/routers/small-business-rv-series-routers/models-comparison.html
BB
Which other router can i use of less cost in place of rv for port forwarding
Is isr1102-4p ok or 800 or 900 series
@adeebtaqui
That is correct, those are the next level, enterprise models and the Meraki Go security gateway and Meraki cloud-based SD-WAN appliances (https://meraki.cisco.com/products/security-sd-wan/ and https://www.meraki-go.com/products/security-gateway/ )There will be entry-level CBR (Cisco Business Router) but yet we could not commit any timeline.
Martin Aleksandrov
None of the CBS and entry-level Cisco switches does support NAT. You can take a look at Cat4K and Cat6K switches.
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/29283-166.html
