04-04-2022 07:26 AM
I have gone thorough many datasheets but couldn't find a correct one..and now i am confused. I would appreciate if any one can help me out if CBS350 supports routing protocols like ospf, bgp etc. and PTP?
04-04-2022 07:31 AM
The only protocol that is explict mentioned on the doc is RIP v2. But, it mention IPv4 routing so I´d say it can support other protocols as well.
04-04-2022 07:51 AM - edited 04-04-2022 07:52 AM
Thank you Flavio, it would be great if I can get a exact answers before purchasing CBS350..
04-04-2022 08:04 AM
Yeah, you can read by your own. Let´s me share the link.
But if you are not comfortable with the doc, you can open up a TAC case and confirm exactly.
But I pretty sure it can suppor. You can see here on this link someone showing ospf config.
https://www.reddit.com/r/Cisco/comments/sbryxi/need_help_with_ospf_on_my_cbs350_switch/
Also, you can confirm with sellers.
07-18-2023 01:48 PM
Not at all. CBS350 generally support only static routing.
Only special and expensive Switches with x marked and with special OS support rip v2
04-04-2022 08:19 AM
Thank you and appreciated I have already went through the doc and after that I got confused.. I guess will raise a TAC let's see if they can help.
04-04-2022 09:06 AM
Please note, that the CBS350 series switches do support static routing and RIPv2 dynamic routing only. Other routing protocols such as BGP and OSPF are not supported. The information provided in the datasheet is correct.
07-18-2023 01:47 PM
Not at all. CBS350 generally support only static routing. Only special and expensive Switches with x marked and with special OS support rip v2
