Does CBS350 supports routing protocols like ospf, bgp etc. and PTP?
sathyajith
I have gone thorough many datasheets but couldn't find a correct one..and now i am confused. I would appreciate if any one can help me out if CBS350 supports routing protocols like ospf, bgp etc. and PTP?
8 Replies 8
The only protocol that is explict mentioned on the doc is RIP v2.  But, it mention IPv4 routing so I´d say it can support other protocols as well.
Thank you Flavio, it would be great if I can get a exact answers before purchasing CBS350..
Yeah, you can read by  your own. Let´s me share the link.
https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html
But if you are not comfortable with the doc, you can open up a TAC case and confirm exactly.
But I pretty sure it can suppor. You can see here on this link someone showing ospf config.
https://www.reddit.com/r/Cisco/comments/sbryxi/need_help_with_ospf_on_my_cbs350_switch/
Also, you can confirm with sellers.
Not at all. CBS350 generally support only static routing.
Only special and expensive Switches with x marked and with special OS support rip v2
sathyajith
Thank you and appreciated I have already went through the doc and after that I got confused.. I guess will raise a TAC let's see if they can help.
@sathyajith
@Flavio Miranda
Please note, that the CBS350 series switches do support static routing and RIPv2 dynamic routing only. Other routing protocols such as BGP and OSPF are not supported. The information provided in the datasheet is correct.
Not at all. CBS350 generally support only static routing. Only special and expensive Switches with x marked and with special OS support rip v2
ARIEH_GmbH
Not at all ... CBS350-Series are a SOHO-Switches and not Enterprise-Switches as Catalyst 9300-Series ... BGP, OSPF, are Protocols for Enterprise-Switches only ...
CBS350 supports only Static Routing and Dynamic Routing of the Protocol RIPv2 ...
