Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2841 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4390 Views
  • 1 replies
  • 16 Helpful votes
Despite having the console timeout set for 30 minutes, an SG350-28P running firmware 2.3.5.63 is kicking me out after a few seconds to a minute or so.  I've not used a stop watch, but it's definitely not 30 minutes (nor was it 10 which is the default...
Terabyte by Level 1
  • 13697 Views
  • 64 replies
Hello, I have an SF300 and I was browsing to find which type of cabling I would need to buy, I understand that it's a female db9, but I was curious if it was any or if it had to follow a specific type. As well as if there's any recommendations for wh...
guzmang by Level 1
  • 350 Views
  • 5 replies
