08-04-2014 08:39 AM
I am trying to download a new configuration file into the switch and it keeps saying:
Bytes Transferred: 0
Status: Copy failed
Error Message: Copy: Error in configuration download Line: 1 Command: no cdp run
The file that i am trying to submit is .txt file
08-04-2014 12:45 PM
Good Afternoon,
Which (model) switch are you trying this on?
Raquel
08-05-2014 02:00 AM
I am using SF302-08MP with the last firmware version (1.3.7.18)
bestregards,
Rui Fernando
08-05-2014 03:09 AM
Hi Fernadno,
Have you tried to remove "no cdp run" line from the txt file and upload it again.
Aleksandra
08-05-2014 03:18 AM
yes but then it comes back with another error...
"spanning-tree bpdu filtering"
08-05-2014 03:27 AM
Hi Fernando,
Have you try just to do current configuration backup and upload? To see if the process itself is not failing.
Aleksandra
08-07-2014 08:18 AM
Hi Fernando,
I have redone the whole configuration for you so I hope it works. Please note that there was a important change in switch file system on versions 1.3 thus this might be the reason for uploading old configuration issue and manual reconfiguration was needed.
Aleksandra
08-05-2014 08:00 AM
Try to log in to the console and paste a small section of the config at a time until it is complete and see what commands it doesn't like.
Also, is it possible you're using a confg file from something like a SG300 and trying to load it in to a SF300 or from a SX500 in to a SX300? Or a config file from a different switch using a different software version?
08-05-2014 10:56 AM
I just ran a quick test on the SF302-08MP. I made a backup of my running "default" config file and then tried to download it as a new config file. There might be something you changed that is causing this to happen. I have attached my running config file.
There are no special configurations or changes I have made to the switch. Compare yours to the one I have attached and let me know what is different. Also, if you can, send me the file you are trying to download and I can try running it over here.
Raquel
12-12-2017 04:24 PM
