Duplicated IP interface on the same subnet when configuring port-channel (L3)
ptoumbas2011
Hi, I am trying to configure port-channel on SG300 L3 switch. When i try to assign an ip to the interface i get the following error:
Sw2Fl4(config-if)#ip address 192.168.2.16 255.255.255.0
Duplicated IP interface on the same subnet.
The management ip of the switch is in the same subnet (192.1682.10). Why it wont let me to have another IP assigned to another interface?  Olny 1 interface can use an ip form the same subnet? Below is my current config :
config-file-header
switchcf920f
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
spanning-tree bpdu filtering
vlan database
vlan 100,200
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname switchcf920f
line console
no autobaud
exit
interface vlan 100
 name Management
 ip address 192.168.2.10 255.255.255.0
interface vlan 200
 name Guest
interface gigabitethernet1
 switchport mode access
 switchport access vlan 100
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet7
interface gigabitethernet8
 switchport trunk allowed vlan add 200
 switchport trunk native vlan 100
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
 switchport access vlan 200
interface gigabitethernet18
 no negotiation
 no spanning-tree portfast
interface gigabitethernet19
interface gigabitethernet20
 no negotiation
interface Port-channel1
 description SW
exit
Please advise. Thank you
Kind regards
Petros
The switch is correct, listen to it! :)
You are trying to create a new broadcast domain, with the same IP address as another broadcast domain, on the same device. It would be the same as you were trying to configure VLAN 200 with IP address of 192.168.2.20. That would not work either.
What you should do is to create a layer 2 port-channel and assign it to VLAN 100 or continue creating a layer 3 port-channel and assign an IP address of a different subnet.
Thank you Henrik for the reply,
It was my mistake not to think of it earlier. I have already configured my etherchannel using L2 ports, as i have found it more appropriate based on the company needs. All ports are trunked and assigned to same channel-group. Port-channel was automatically created for L2 as well.
Thank you
