Etherchannel failing to remote site
simon.howard
Hi, I'm setting up a new server (Dell PE R730 with vmWare Esxi6) for Etherchannel on 2 of it's ports yet it's failing in a wierd way. I've done this before without any problems but when I plug both connections in it pings back fine locally, yet fails when I try pinging it from a remote site (where our vSphere host is located). If you disconnect one of the nic cables the server can be pinged by both sites and vSphere but this removes its redundancy which I need.
The config is below with the EC in question being Port-Group 5:
Group: 5
Group state = L2
Ports: 2   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Gi2/0/24
Port state    = Up Mstr In-Bndl
Channel group = 5           Mode = On              Gcchange = -
Port-channel  = Po5         GC   =   -             Pseudo port-channel = Po5
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 0d:00h:05m:26s
Port: Gi5/0/24
Age of the port in the current state: 0d:00h:07m:39s
                Port-channels in the group:
Port-channel: Po5
Age of the Port-channel   = 3d:18h:33m:03s
Logical slot/port   = 12/5          Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi2/0/24 On                 0
  0     00     Gi5/0/24 On                 0
swnavlhr5#show running-config
Building configuration...
Current configuration : 15503 bytes
! Last configuration change at 09:38:06 UTC Fri Mar 17 2017
version 15.2
no service pad
service compress-config
service sequence-numbers
hostname swnavlhr5
boot-start-marker
boot system switch all flash:cat3k_caa-universalk9.SPA.03.07.02.E.152-3.E2.bin
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 10000000
no logging console
switch 1 provision ws-c3650-48tq
switch 2 provision ws-c3650-48tq
switch 3 provision ws-c3650-48tq
switch 4 provision ws-c3650-48tq
switch 5 provision ws-c3650-48tq
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-1661342321
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1661342321
 revocation-check none
 rsakeypair TP-self-signed-1661342321
system mtu 9014
diagnostic bootup level minimal
spanning-tree mode pvst
spanning-tree portfast default
hw-switch switch 1 logging onboard message level 3
hw-switch switch 2 logging onboard message level 3
hw-switch switch 3 logging onboard message level 3
hw-switch switch 4 logging onboard message level 3
hw-switch switch 5 logging onboard message level 3
redundancy
 mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
 class non-client-nrt-class
  bandwidth remaining ratio 10
interface Port-channel1
 switchport mode access
interface Port-channel2
interface Port-channel3
interface Port-channel4
interface Port-channel5
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 switchport trunk allowed vlan 1
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface GigabitEthernet2/0/1
 switchport access vlan 2
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
 switchport access vlan 3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
 switchport access vlan 4
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
 switchport access vlan 5
 switchport trunk allowed vlan 2
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
 switchport access vlan 6
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
 switchport access vlan 7
interface GigabitEthernet2/0/19
 channel-group 2 mode on
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
 switchport access vlan 8
interface GigabitEthernet2/0/24
 channel-group 5 mode on
interface GigabitEthernet2/0/25
 channel-group 4 mode on
interface GigabitEthernet2/0/26
 description NavLHR1 Wifi
interface GigabitEthernet2/0/27
 switchport access vlan 10
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
 switchport trunk allowed vlan 10
interface GigabitEthernet2/0/31
 channel-group 3 mode on
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
 channel-group 1 mode on
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
 switchport mode trunk
 switchport nonegotiate
interface GigabitEthernet3/0/1
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
interface GigabitEthernet3/0/5
interface GigabitEthernet3/0/6
interface GigabitEthernet3/0/7
interface GigabitEthernet3/0/8
interface GigabitEthernet3/0/9
interface GigabitEthernet3/0/10
interface GigabitEthernet3/0/11
interface GigabitEthernet3/0/12
interface GigabitEthernet3/0/13
interface GigabitEthernet3/0/14
interface GigabitEthernet3/0/15
interface GigabitEthernet3/0/16
interface GigabitEthernet3/0/17
interface GigabitEthernet3/0/18
interface GigabitEthernet3/0/19
interface GigabitEthernet3/0/20
interface GigabitEthernet3/0/21
interface GigabitEthernet3/0/22
interface GigabitEthernet3/0/23
interface GigabitEthernet3/0/24
interface GigabitEthernet3/0/25
interface GigabitEthernet3/0/26
interface GigabitEthernet3/0/27
interface GigabitEthernet3/0/28
interface GigabitEthernet3/0/29
interface GigabitEthernet3/0/30
interface GigabitEthernet3/0/31
interface GigabitEthernet3/0/32
interface GigabitEthernet3/0/33
interface GigabitEthernet3/0/34
interface GigabitEthernet3/0/35
interface GigabitEthernet3/0/36
interface GigabitEthernet3/0/37
interface GigabitEthernet3/0/38
interface GigabitEthernet3/0/39
interface GigabitEthernet3/0/40
interface GigabitEthernet3/0/41
interface GigabitEthernet3/0/42
interface GigabitEthernet3/0/43
interface GigabitEthernet3/0/44
interface GigabitEthernet3/0/45
interface GigabitEthernet3/0/46
interface GigabitEthernet3/0/47
interface GigabitEthernet3/0/48
interface TenGigabitEthernet3/1/1
interface TenGigabitEthernet3/1/2
interface TenGigabitEthernet3/1/3
interface TenGigabitEthernet3/1/4
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
interface GigabitEthernet4/0/3
interface GigabitEthernet4/0/4
interface GigabitEthernet4/0/5
interface GigabitEthernet4/0/6
interface GigabitEthernet4/0/7
interface GigabitEthernet4/0/8
interface GigabitEthernet4/0/9
interface GigabitEthernet4/0/10
interface GigabitEthernet4/0/11
interface GigabitEthernet4/0/12
interface GigabitEthernet4/0/13
interface GigabitEthernet4/0/14
interface GigabitEthernet4/0/15
interface GigabitEthernet4/0/16
interface GigabitEthernet4/0/17
interface GigabitEthernet4/0/18
interface GigabitEthernet4/0/19
interface GigabitEthernet4/0/20
interface GigabitEthernet4/0/21
interface GigabitEthernet4/0/22
interface GigabitEthernet4/0/23
interface GigabitEthernet4/0/24
interface GigabitEthernet4/0/25
interface GigabitEthernet4/0/26
interface GigabitEthernet4/0/27
interface GigabitEthernet4/0/28
interface GigabitEthernet4/0/29
interface GigabitEthernet4/0/30
interface GigabitEthernet4/0/31
interface GigabitEthernet4/0/32
interface GigabitEthernet4/0/33
interface GigabitEthernet4/0/34
interface GigabitEthernet4/0/35
interface GigabitEthernet4/0/36
interface GigabitEthernet4/0/37
interface GigabitEthernet4/0/38
interface GigabitEthernet4/0/39
interface GigabitEthernet4/0/40
interface GigabitEthernet4/0/41
interface GigabitEthernet4/0/42
interface GigabitEthernet4/0/43
interface GigabitEthernet4/0/44
interface GigabitEthernet4/0/45
interface GigabitEthernet4/0/46
interface GigabitEthernet4/0/47
interface GigabitEthernet4/0/48
interface TenGigabitEthernet4/1/1
interface TenGigabitEthernet4/1/2
interface TenGigabitEthernet4/1/3
interface TenGigabitEthernet4/1/4
interface GigabitEthernet5/0/1
interface GigabitEthernet5/0/2
interface GigabitEthernet5/0/3
interface GigabitEthernet5/0/4
interface GigabitEthernet5/0/5
interface GigabitEthernet5/0/6
interface GigabitEthernet5/0/7
interface GigabitEthernet5/0/8
interface GigabitEthernet5/0/9
interface GigabitEthernet5/0/10
interface GigabitEthernet5/0/11
interface GigabitEthernet5/0/12
interface GigabitEthernet5/0/13
interface GigabitEthernet5/0/14
interface GigabitEthernet5/0/15
interface GigabitEthernet5/0/16
interface GigabitEthernet5/0/17
interface GigabitEthernet5/0/18
interface GigabitEthernet5/0/19
interface GigabitEthernet5/0/20
interface GigabitEthernet5/0/21
interface GigabitEthernet5/0/22
interface GigabitEthernet5/0/23
interface GigabitEthernet5/0/24
interface GigabitEthernet5/0/25
interface GigabitEthernet5/0/26
interface GigabitEthernet5/0/27
interface GigabitEthernet5/0/28
interface GigabitEthernet5/0/29
interface GigabitEthernet5/0/30
interface GigabitEthernet5/0/31
interface GigabitEthernet5/0/32
interface GigabitEthernet5/0/33
interface GigabitEthernet5/0/34
interface GigabitEthernet5/0/35
interface GigabitEthernet5/0/36
interface GigabitEthernet5/0/37
interface GigabitEthernet5/0/38
interface GigabitEthernet5/0/39
interface GigabitEthernet5/0/40
interface GigabitEthernet5/0/41
interface GigabitEthernet5/0/42
interface GigabitEthernet5/0/43
interface GigabitEthernet5/0/44
interface GigabitEthernet5/0/45
interface GigabitEthernet5/0/46
interface GigabitEthernet5/0/47
interface GigabitEthernet5/0/48
interface TenGigabitEthernet5/1/1
interface TenGigabitEthernet5/1/2
interface TenGigabitEthernet5/1/3
interface TenGigabitEthernet5/1/4
interface Vlan1
 ip address 192.168.85.160 255.255.254.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap group default-group
end
0 Replies 0
