Fan noise of 350x-24
KnutHerzog74170
Dear all,
I just received a 350x-24. The fan is quite loud, but that isn't a problem as no one sits beside the rack.
I just wondered if a noise of 49.2dB average is normal or if it is a indiaction for a hardware or config problem?
The noise level was just measured with a iPhone not some professional noise meter.
Knut
balaji.bandi
Look at the product specification and noise level - if they make more than mentioned and not acceptable worth raise a ticket with TAC.
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html
BB
I've actually measured the noise and it is 70db ¿hoy can I open a ticket? Can't find the right option!
