file prompt quiet on Cisco SmallBusiness SG350
Is there an equivalent of "file prompt quiet" in Cisco SmallBusiness SG350?
I am trying to automate a task, however, in order to complete it, I need to save the configurations. My problem arises when I need to type "Yes".
Using other Cisco Devices, I use the command "file prompt quiet" and it works just fine. With the SG350, it doesn't work.
Any help will be very appreciated.
Thanks.
marce1000
 - That command is IOS based and not available on SG-devices, check if a proposed solution (modified to your needs) in this  thread can be applicable :
                  https://community.cisco.com/t5/routing/copy-to-running-without-confirmation/td-p/591661
 M.
Thank you very much sir.
