Who has a Switch CBS?
ccz
Please can you help me with this information:
The Switch CBS350 supports IP SLA commands?
track 25 ip sla 25 reachability
ip sla 25
icmp-echo x.x.x.x
timeout 1000
frequency 5
ip sla schedule 25 life forever start-time now
ip sla enable reaction-alerts
ip route 0.0.0.0 0.0.0.0 x.x.x.x name Ruta track 25
I have found this link that the CBS250 and CBS350 apparently support IP SLA completely.
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2247-configure-ip-sla-tracking-for-ipv4-static-routes-on-a-cbs.html
However, the emulator offered by Cisco does not have the option to configure IP SLA through the web interface. Is it possible to configure it by CLI?
Thanks.
8 Replies 8
balaji.bandi
CBS does support IP SLA. v3.0 Emulator, right side basic to advanced and check if you find that option.
BB
Hi Balaji B.
Thanks for you response.
I am seeing the Advanced view in the emulator and there is no IP SLA option.
Emulator v3.0:
https://www.cisco.com/web/fw/tools/cisco-business/emulators/switch/cbs/cbs350/cbs350-48fp-4x/html/cbs/config/log_off_page.html?moduleType=2138
Thanks.
I am guessing this is more to do on the command level in relation to this feature. (i do not have a device to test it) - go with document only.
BB
CoreyP319
Hi CCZ,
IP SLA is not supported on CBS devices. Here's a link to the data sheet for additional specs.
Hi CoreyP319.
Thanks. However, I´m confused as the following Cisco documentation tells how to configure IP SLA on CBS350s.
This is not very clear.
Have you configured a CBS350?
Martin Aleksandrov
Hi ccz,
IP SLA is no longer supported with the CBS350/CBS250 series switches. We apologize for the confusion.
Martin
Hi Martin.
Thanks for your response. Which Small Business Series Switches fully support IP SLA?
Thanks.
Hi ccz,
IP SLA is an Sx550 series switches feature only and is simple support of IP SLA ICMP-Echo operations. Please refer to "Using SLA" section from the product administration guide: https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf (page 419)
Martin
